WMP Series Reseter
First post, by Roland User
Hi )
I'm create WMP Series Reseter
Q: What for this need ?
A : This need for correctly reset all MIDI devies in WMP Series players
This solution do find all WMP series player embeded WMP to Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11 , also this solution do find MPC , Home Cinema , Black Edition and after detectd each asked you use , if you reject , solution will find next , and if you do reject all , so solution simply do reset your device and all ) for correctly work you need also this Vista+ MIDI Switcher , at least for set device whitch will do recive reset )
Official GitHub repository : https://github.com/SUGHuser/WMP-Series-Reseter (this repository can and will refreshable) , and this repositori in refreshed process can will be unavailable
Oficial link on MediaFire: https://www.mediafire.com/file/qkchhrndff25mk … eseter.zip/file (this link will refreshable)
