CUPS4NT is a print system modelled on CUPS for Windows NT 4.0 SP6a, and the same package also runs on Windows 10 and 11. At its core is the print server cupsd4nt, which runs as a Windows service. Alongside it come a custom PostScript printer driver, a wizard for setting up printers and a management tool. Printers are reached over IPP, IPPS and IPP Everywhere, LPD, port 9100, USB, IPP over USB or the local ports.
Printers without PostScript are no obstacle: the server converts pages into PCL, Epson ESC/P-R and ESC/P2, or the languages of label and receipt printers. Through the built-in Gutenprint it also supports about 3,600 further models, mainly inkjets from Epson, Canon and HP. Its output is byte-identical to Gutenprint on Linux, and the pages come out exactly to scale. PostScript and PDF from Linux or Mac computers are rasterised by the server with Ghostscript.
Setting up a printer is largely automatic. The wizard searches the network and the ports, recognises the model from its device ID and picks the right driver from over 10,000 models, and a search box helps where it doesn't. If you want more, you can load about 6,600 additional PPDs from the Ubuntu archive after accepting their licences. The web interface is secured with HTTPS and Windows accounts, and it can be switched off completely. Confidential printing with a PIN is also available. Everything is available in English, German and French. The small setup is about 5 MB, the full one about 96 MB. (96mb is to large)
Printers that speak PostScript
The Windows driver produces PostScript with all PPD options (trays, duplex, finishing, quality …) and the server passes it straight through.
Printers without PostScript – built-in printer languages
cupsd4nt converts pages into the printer's own language:
PDF, IPP Everywhere (PWG raster passed through unchanged), PostScript
PCL 5e / 5c, PCL 6 (PCL XL), HP RTL, HP-GL/2 (plotters)
Epson ESC/P-R and ESC/P-R2, ESC/P2, ESC/P 9/24-pin, IBM Proprinter
Receipt and label printers: ESC/POS, Zebra ZPL II, EPL2, TSPL, CPCL, Datamax DPL
Gutenprint 5.3.4 – about 3,600 printer models
PostScript and PDF from other computers
Linux or Mac clients can print PostScript/PDF to cupsd4nt, even to printers without PostScript: the server rasterises the document with Ghostscript and then uses the matching printer language or Gutenprint. This is only needed for jobs from other computers, because the Windows driver already delivers raster data. For that reason Ghostscript is only included in the full setup.
Optional: PPDs from the Ubuntu archive
The small setup has no PPD library. On request, CUPS4NT downloads the Ubuntu package openprinting-ppds (5.4 MB, about 6,600 PPDs for PostScript printers):
Web interface in CUPS 2.4 style (printers, jobs, administration, help), plus a page to find and add printers, the server log and PIN release
USB
NT 4.0:
classic USB printers via the separate usbnt.sys driver (usb://Manufacturer/Model)
IPP over USB for modern printers and multifunction devices
Windows 10/11: USB printers via Windows' own usbprint.sys (not yet tested on real hardware)
Windows 10 / 11
Same setup; it detects the system and installs the server, service, firewall rule for port 631, tools and Start menu entries
Printing path: Windows printer → local port \\.\pipe\cupsd4nt_<queue> → cupsd4nt → printer
Driver: the same CUPS4NT driver as a user-mode (v3) driver with the same PPD tabs as on NT 4.0
If a printer with the same driver and PPD already exists, the driver is reused instead of replaced (avoids "file in use" errors)
Windows 11 24H2: "Windows Protected Print" must be off
Diagnostic tool c4win bericht collects logs, ports, drivers and printers into one ZIP
Management tools
Printer management (cups4mgr): Windows printers and server queues/jobs in one tool, with pause, resume, cancel, default printer, sharing, properties, test page, PIN release and server settings
Control Panel entries: "Set up printer", "Printer management" and "Print server management"
Print settings dialog: all PPD options on their own tabs (grouped by the PPD, or sorted into Paper, Quality, Colour, Finishing, Job and More)
feedbacks please
