First post, by Novanianer
Update:
Quality Update RTL 8111D
RTL 8812AE (WIFI) with wifi client - nt4-netz-setup(3).exe
PipeWire Soundcard (you need a linux host) - PWWAVE
There Com,
here some driver for NT4 (SP6).
RTL 8111D - network card driver
ALC889 - audio codes HDA driver (only stereo output and line in, micro, support frontpanel)
EMU10K1 - driver, the orginal driver dont work good on my card, this driver support ony stereo output ; dont use the midi driver 😉 (wip)
greetings
Reply 1 of 7, by Novanianer
emu10k1 - quality update
PAUC - is a pulse audio driver for nt4. you stream the audio content to a other computer. you can set settings on control panel,there s a cpl file.
for linux, run "pactl load-module module-simple-protocol-tcp rate=44100 format=s16le channels=2 playback=1 port=4711 listen=0.0.0.0" .
Reply 2 of 7, by digger
Cool! A PulseAudio client driver is also a nice virtualization solution, since it doesn't require a sound card to be emulated in the VM.
Alternatively, a virtio-sound guest driver for NT4 would also be an interesting solution.
Thanks for sharing! 😃
Reply 3 of 7, by Novanianer
Novanianer wrote on 2026-09-28, 16:30:
Update: […]
Update:
There Com,
greetings
Update:
Reply 4 of 7, by Novanianer
Update: […]
Update:
There Com,
greetings
Fixed: RTL 8111D Settings dont open.
Reply 5 of 7, by Novanianer
Update: […]
Update:
There Com,
greetings
add Intel I219-V driver (beta)
Reply 6 of 7, by Novanianer
Novanianer wrote on 2026-11-19, 19:00:
Update: […]
Update:
There Com,
greetings
update i219 v driver
the installer support rtl8111d 8812ae intel 219v and network monitor with wpa gui
feedback please
Reply 7 of 7, by Novanianer
add intel HD Audio 300 driver
support front Audio out and Micro
Audio over speaker
Audio over HDMI
the output can you change over sndvol32
