First post, by dulu
As the title suggests, I planned to use a Logitech MX Mechanical keyboard and a mouse, and switch between my main PC and a retro machine (440BX). Unfortunately, the Logitech Bolt receiver doesn't work in the BIOS. The only sign of life occurs when I hold down the F8 key—that’s when the PC speaker starts beeping. The keyboard works fine in Windows 98. Has anyone encountered a similar issue and, by some miracle, knows a solution? I’d really like to stick with the MX Mechanical, but unfortunately, it only comes with the Bolt receiver. I just borrowed an older Logitech MX Keys keyboard from a friend, which uses the Unifying receiver—and that one works flawlessly in the BIOS.
