First post, by asic28
Hi all,
I'd like to share a project that may interest some of you: ScratchPsx, a PlayStation 1 emulator running natively under MS-DOS (DOS/4GW, built with Open Watcom).
Features:
MIPS R3000 → x86 dynamic recompiler
Video: VGA 320x200, mode X 320x240 (256 colors, dithered), VESA 640x480x16
3dfx Glide 3 renderer for Voodoo Graphics and Voodoo 2 (SLI handled by Glide): polygons, sprites and textures drawn by the card at 640x480, palettized textures with chroma-key transparency
Sound Blaster 2.0 / Pro / 16 (up to 44.1 kHz 16-bit stereo, CD audio and XA)
An in-game menu GUI as a tribute to Genecyst (yes, with the dripping blood)
Status: so far it has been tested under DOSBox-X (emulated Voodoo 1). Crash Bandicoot and Tekken 2 boot and play, amongst almost all ps1 library.
Under emulation the Glide path isn't faster, which is expected. I'll test it soon on my real machines: a 486DX4-100 with a PCI Voodoo 1, and a P2-350 with 2× Voodoo 2 in SLI.
Known limitations of the Glide renderer: no mask bits, no read-back of what the card drew, and subtractive blending is approximated (the Voodoo can't subtract).
It's freeware.
The archive includes the MSDOS versions (three executables (VGA/VESA, Voodoo 1, Voodoo 2), DOS4GW) and the Windows version.
Check this video (DosBox-X)
https://www.youtube.com/watch?v=KK65ccNZhUY
Feedback and reports from real hardware are very welcome, especially speed on Pentium / P2 class machines and other Voodoo cards. Feel free to post your SCRPSX.LOG if something goes wrong.
Cheers,
Reason: Copyright
Reply 1 of 20, by asic28
Here are some screenshots
Reply 2 of 20, by theelf
Hi tanks!love the interface, hope more emus have similar ones, like nesticle, callus, zsnes etc
About the emu, i tested in a 233MMX no voodoo, S3 Virge 4mb, and work! cool, tested a not much demanding game, megaman x6, the problem is like 2fps
Love the 256 color dithering by the way, is super nice
Reply 3 of 20, by zyzzle
Great to have another fine emulator for pure DOS. Thanks for posting.
Reply 4 of 20, by brotalnia
I decided to test this on real hardware and record the performance. Unfortunately the voodoo 2 mode didn't work for me, and it was quite slow on my pentium 3.
https://www.youtube.com/watch?v=ivdA_hIJ2K8
Reply 5 of 20, by asic28
Software rendering is quite accurate so will slow down things a lot.
Sorry for the disapointment i did my best
Reply 6 of 20, by asic28
Anyway, thanks for testing! Just to set expectations: ScratchPsx targets real DOS machines (486 to Pentium II). Under DOSBox it is an emulator running inside an emulator, so it's much slower than a native Windows emulator like ePSXe, which uses a modern CPU and the GPU. Without a 3dfx card, everything (CPU emulation and drawing) is done in software, which was already heavy on 90s hardware. The point of the project is running on period hardware, ideally with a Voodoo. Real hardware results coming soon.
Reply 7 of 20, by asic28
For all who have tested the emu, can you send me the SCRPSX.LOG file please ?
Reply 8 of 20, by asic28
I have some more news concerning performance. Coming soon
Reply 9 of 20, by zyzzle
I'm going to test this soon on intel core processors. It should run like a dream. I don't have my bootable USB memory stick with me at the moment. It will be interesting to see how total software performance (no Voodoo card on an intel i5-8250 CPU!) will be. I'll try on a Broadwell (i7-5600 @ 3.2 Ghz with mtrrlfbe loaded to speed up LFB graphics) and compare to my Kabylake system above @ 3.4 Ghz with NO mtrrlfbe (since its vbios is broken / won't allow LFB writecombining to be set).
Does your emulator support bank switching mode for its graphics as opposed or alternatively to LFB access mode? If it supports bankswitching, then its performance would be optimal on systems with broken onboard vbioses like Intel 6th-10th gen icore systems which have no such limitations in bankswitched mode when accessing VESA modes at 640x480 or above.
I think PS1 graphics were 320x240 native, though? Or were some games 640x480?
Reply 10 of 20, by asic28
Wait for the new release. Coming soon today
Reply 11 of 20, by keropi
zyzzle wrote on 2026-10-06, 09:24:
there is the "high-res" interlaced mode on ps1 that is used often in games for menus , inventory screens etc - games changed resolution during these segments
I tested the emu on my test p133 system with a virge vga and 16mb ram , tried to load castlevania symphony of the night , it works but it is very slow - I am getting 2fps on the bios logo and sound disabled - plain vga mode
I guess this needs a voodoo card to be playable, correct?
Reply 12 of 20, by keropi
left it running and went to do some chores and when I returned 30mins later the system had rebooted
the LOG was 0 bytes so I cannot upload anything from that run
I loaded again to bios and I get this on the log, I suppose there is not much hope atm since 16mb of ram just does not cut it
Reply 14 of 20, by asic28
And new release here
Reason: Copyright
Reply 15 of 20, by megatog615
Is the source code available?
Your AI slop bores me.
Reply 16 of 20, by asic28
not yet
Reply 17 of 20, by amadeus777999
Awesome!
Reply 18 of 20, by Laaca
I do not see any link for download...
Reply 19 of 20, by theelf
Laaca wrote on 2026-10-06, 21:46:
i think was removed because the bios
I upload without bios until priginal developer do
The attachment SCRPSX.zip is no longer available
