First post, by ]--Freeman--[
Hi! I have a big problem building a 486 computer related with the height, in an at case.
If I use 6'33mm standoffs I can't install pci or simm cards because the L form of the bracket contacts with the area where I fix with the screws the card before inserts in pci/simm slot. However, if I use 10mm standoffs I can install pci or simm card without problems, but the din 5 connector is not aligned with the hole from chassis and I can't connect the ps2 keyboard adapter. With 6'33mm the din connector is aligned and I can connect the adapter narrowly, but ok.
I've been thinking but with a 8 mm standoff the results will be the same than 10mm.
I don't know what to do. That's the first time I've found an scenary like this. I'm trying modifying the L form so that I can connect the pci card but I don't know if it is the good way. I don't want to disolder the din connector and solder cables...
Any help is welcomed.
Thanks a lot.
Reply 1 of 8, by BitWrangler
Sometimes it's a case of loosen everything off, including screws that hold the case together and the motherboard tray on, if removable, and jiggle it until it fits. 1/4" or 6mm should be right unless somehow it's had the motherboard tray swapped from another case or it somehow fitted upside down, or it's slotted in wrong if screwless.
Reply 2 of 8, by ]--Freeman--[
I've solved the problem with 8mm standoffs. But now I am trying to set the fsb to 33Mhz in jp18. However my jp18 has only 4 pins and not 6. It's a Lucky star Ls486e Rev 1. This revision doesn't have manual...
Reply 3 of 8, by BitWrangler
It seems likely to me, that you would have the 1-2 of the 6 pin missing, of later revs, so your 1-2 = 3-4 and your 3-4 = 5-6.
Reply 4 of 8, by ]--Freeman--[
BitWrangler wrote on 2026-10-13, 10:30:
But that means i can't set my fsb at 33 Mhz because 5-6 don't use in these manual to set fsb. It's always without jumper.
Reply 5 of 8, by BitWrangler
I must be looking at a different alternate version than you, the one I saw had settings over 50 on 1-2 and on the second 2 jumpers it was off off for 25, on on for 33, off on for 40 and on off for 50.
Reply 6 of 8, by wierd_w
For that small a clearance difference, using a jig to polish/sand off the tops of the brass standoffs (please assure they all come out the same height!) Could get you there?
Reply 7 of 8, by ]--Freeman--[
BitWrangler wrote on 2026-10-13, 14:03:
Gotcha!! 😀 😀 It is 1-2 on and 3-4 on. That matchs with the fsb jumper settings from Rev D of this motherboard.
Thanks Bitwrangler!!
Reply 8 of 8, by ]--Freeman--[
wierd_w wrote on 2026-10-13, 14:32:
Yess! I got the good height! It's 8 mm! I have to cut and polish a 10mm nylon standoffs and the screws so that I can fix them to the tray. Additionally, I've put hot glue to strengthen the points.
