First post, by Herman BRULE
Hi,
I dev BIOS from scratch (into 12h, based on coreboot/seabios/iPXE/memtest86+) for mb-8433UUD.
My main problems are:
  • Lack for PCI diag and info
  • NO USB diag/info/support, I need boot on USB and use USB keyboard
  • memtest86+ directly into the BIOS
  • speedsys DOS like directly into the BIOS
  • iPXE directly into the BIOS to have diskless boot, include without network card ROM chip
  • dump for chipset and other key info
  • hurge fuzzing/test case base to have stable BIOS (EG try null size HDD, negative size, buggy device, 1TB HDD, ...)
  • Fix 86Box for accruate emulation to dev mostly with the emulator
  • Fix for coreboot/SeaBIOS on real 486
https://github.com/alphaonex86/mb-8433UUD-A-BIOS
I have PCI USB card, PCI ethernet card, PCI VGA card, 32MB RAM with 6.18 LTS Linux kernel, real HDD, MS-DOS 6.22 part to play with game.
I plan to replace to SSD, fanless power supply, and maybe dev my own CPU (FPGA based)...
Dev of Ultracopier
Reply 1 of 1, by jmarsh
Of course it's made with AI.
