First post, by superfury
The documentation on the ET4000/W32P STG1702 I can't seem to find anywhere.
But the STG1703 can be found, with entries matching those modes I see explained in WhatVGA (only up to a certain register though, where the documentation abruptly ends).
Oddly enough, I see two interesting modes in there:
Mode 6: 16-bit 5:6:5 direct color (2ψ8-bit input)
Mode 7: 8-bit indexed color (2ψ4-bit input)
Mode 8: 15-bit direct color (2ψ8-bit input)
Those seem like the equivalents of modes 0(8-bit), 2(15-bit) and 3(16-bit), but 2 VCLKs per pixel instead of 1?
Also, what happens during the modes when these extensions aren't enabled (the AT&T 20C490-compatible modes when bit 3 of the DAC command register cleared)? Are they identical in behaviour to the AT&T 20C490 chip?
UniPCemu Git repository
Reply 1 of 1, by superfury
I've implemented the 2ψ4 and 2ψ8 modes to simply input 2 8-bit inputs and 2 4-bit inputs for now (which indeed drops the upper 4 bits from the resulting 8-bit pixel, which is rendered like a normal VGA, thus basically the 8-bit attribute controller mode but performed by the DAC instead).
All other modes seem to behave as expected, both using the legacy mode (AT&T 20C490 mode without the DAC command register bit 3 set) and the added 15/16/24-bit direct DAC (PCLK going high and low) modes (with 24-bit being sent as 3x 16-bit, being broken up into a repeat, first pixel (doubled), second pixel to keep it uniform on the screen).
