First post, by LeeDerbyshire
Hi all. I've a non-working ABit AB-PB4 Rev:1.5 that I would love to fix. It was bought off eBay (of course) as being unused; nevertheless it has suffered some physical damage. There is no video output, and there are no beeps at all.
There were some crushed-together legs in one corner of the ALi M1487. The affected pins are: RTCAS, IOWJ, ZSMEMWJ and CPUSPD. I don't really know these do.
There were also some crushed clips in the ISA bus: I/O CH CK/ and DATA 7 were pushed flat into GND and RESET DRV.
I've managed to separate the affected legs and clips and they look okay under magnification, although I haven't yet tried to solder into position the M1487 legs (I have some low-temperature solder paste that I will try with a hot air gun). I'm going to assume that they have been powered-on in the past.
I put one of those very cheap PCI/ISA analysers in, and all I get is four dashes and no POST codes. In the PCI slot, the -12, +12, +5V, CLK, RDY and FRAME LEDs light up; the +3.3V and RESET LEDs do not.
In the ISA slot only the +12, +5V and RDY LEDs light up. The 'manual' for this thing is quite inscrutable, and doesn't mention the ---- output, but I assume it indicates nothing good.
Is it worth persevering with it?
