First post, by MikeBn
Hi all,
so I used the excellent Vogons (Dominus) guide to install Win 3.1 under Dosbox 0.74 and successfully intalled and played games with it (game-cd as image files moutned with IMGMOUNT etc). But I simply cannot make the game Gord@k to work. The game starts fine and the intro works. But as soon as the actual game begins and where for the first time the actual 1st-person-enviroment should be displayed
to walk around in, a windows window pops up:
Directoy Player 4.0
Script Error: Handler not defined
#gPanoMovieObj
I tried either using the quicktime version on the image and also the one linked on the Vogons Guide (2.1.2.59 I think).
Anybody any idea what goes wrong and how to fix it? Maybe someone had a similar problem with a different game
It is also a fresh windows 3.1 install (under Dosbox), so its not like that the windows 3.1 version is totally broken by many installs etc.
Help would be really appreciated,
Mike
PS: What also drives me crazy is that I am 95% sure I did the same thing a year ago (same setup of win 3.1 under dosbox + gordak install) and it worked without problems...
