First post, by llamafarmer2
Hi all
Long time listener, first time caller.. Had it for a while but got a Matrox Mystique 220 (2mb) out of my old compaq system (its an oem board) and trying to pair it up with a voodoo2 for a sweet 98 machine. But lo and behold no Video output on the matrox card. Managed to find a spare agp card to get the machine up so i can try and figure it out and got stuck in a rabbit hole thats gone on for 2 days now and trying to dig out. Stupidly asked gemini for help thinking maybe it can give me some tips (and did to a point but probably vaccuumed from here anyway), but said common problem is bios gets wrecked on these cards. Downloaded some files from a few different joints (here/phils) and managed to get MGAMON to see whats going on. Card is there and returning values (including serial) but the BIOS version was "--". Did a display of the pins values and they came up on screen in a huge list (didn't save and here's the where the problem starts). This matched up with gemini saying bios is borked so thought i would just download the 858-5.bin file and off i went..
That's where it started at least. I should have used the 858-8 version and so it loaded the wrong version (mystique not mystique 220) and screwed a few other things up (my card is 1164 and everything i could see was pointing me to 1064). Serial was now blank and BIOS version became "---" now. Loaded 858-8 but a whole bunch of pins values are gone or corrupted. Did an export now (and saved) and a whole bunch of the values are "255". I was reading another thread on here that pointed to Softpaqs which ended up being a dead end (found drivers but no tools), another thread on here which pointed to some stuff on the wayback machine which was interesting to read but didnt show the values that i needed for my pins file.
Another thread and somebody was generous enough to upload their pins file so i could at least see what they had and match up something to mine but it was for a G200 i think so it wasn't the values i'm after. This was after i was trying to rebuild the file from gemini help with "Echo" commands (running freedos boot with no tools) so its been "fun".
I should also note that when i've been testing, i did read that Mgamon wont display the version because of shadowing with the AGP card installed but anytime i think i make progress i set BIOS to PCI first, power down, remove agp, plug in Matrox, power up, no screen (bios/post is running and get the normal beep in the background saying my date/time are wrong)
Guess what i'm asking is does anybody have a copy of their PINS file for a Matrox Mystique 220 Compaq (OEM) version that i can look at? Or at least something similar so i can go and patch these values enough to get the card working again.
Otherwise if you've got any other suggestions that i can use to try and get this card up and running again
Reply 1 of 2, by PC Hoarder Patrol
llamafarmer2 wrote on 2026-11-01, 10:57:
Hi all […]
Hi all
Welcome to VOGONS 😀
You can find a few Mystique 220 PINS files to examine / try, here under Help > Dead BIOS recovery > PINS files... https://web.archive.org/web/20080512091738/ht … .pl/gbm/matrox/
Reply 2 of 2, by llamafarmer2
PC Hoarder Patrol wrote on 2026-11-01, 16:49:
Hi all […]
Hi all
Welcome to VOGONS 😀
Hey Mate.. Thanks for the help.. The link you gave me led me to the info (or most of it) that i was looking for. Didnt fix my problem but made a couple of tools that might help somebody in the future so will create a seperate thread about those but thanks again..
