First post, by vbug
Hi everyone, I got a toshiba T4700CT laptop, at startup the creen works normally for a few time, but then it turns full white (even on the BIOS screen). It works properly on an external screen. Quick history of that laptop : when I got it, the screen was working properly (but not tested for a long time). The sound card was not working (no sound played). I disassembled it and replaced a 6.3v 1000uf capacitor on the sound card, and the little aluminum encapsulated ones. In addition I replaced two little plastic encapsulated 6.3v 10uf on the main board. Now the sound card is working great but only through the speaker jack, no sound from the speaker. And now when I turn it on, the internal display works normally but after a few time (some seconds) it turns full white. When I turn the screen off via FN+F5 and turn it on back, the screen works properly again for a few seconds then turns back full white. Any idea or suggestions ? Thanks.
