First post, by dwschorfhaar@gmail.c
I have an Aopen AX63PRO. I plan to multi boot it. I can boot windows 98 but when i install Windows XP it seems to install fine but i keep getting a error loading operating system when I try booting for the first time. I can also boot Free Dos on the hard drive. I have tried two different hard drives. a 500 gb sata drive and a 1 TB sata SSD. I have booted Windows 98 from the 500 gb drive fine and Free Dos from the SSD. The version of XP I'm using is service pack 3 integral edition. It is 685 MB in size. I also have a DVD ISO image that is 1.6 GB ish. I get the same error if i try installing that version. I'm connecting the sata drives to the motherboard with this.
StarTech 40-Pin IDE to 2.5in SATA HDD/SSD/ODD Converter, TAA (IDE2SAT2) | PATA to SATA hard and optical drive adapter,
Thank You in advance.
