First post, by Simba823
Hello all! I have a Windows 98 Machine with a P4 and a 9600 Pro. I'm pretty sure the graphics card is dying but wanted some other opinions as it's acting rather bizarre. Mainly in the fact that unreal tournament '99 seems to run fine and can be played as long as I want. But the DXDiag Direct3D tests and other games will cause the screen to go black and then scandisk to appear before booting back to desktop. The card will also sometimes fail to be picked up on by the mobo and it will default to the integrated. The last point is that only once did 98 start up and large parts of the screen in a pattern were a garbled mess.
Reply 1 of 1, by myne
Find a vram tester program.
It's likely unreal is using less vram than other games.
Don't use the bad ram = no consequences
I built:
