First post, by TheMysteriousGray
Hi,
I've been trying to set up a multi-OS retro PC like Shponglefan's system and I've hit a major snag. I installed NVIDIA's display drivers version 45.23, but whenever I try to boot into Windows 98 SE, the splash screen suddenly turns several weird rainbow colors and then I get no screen at all. If I try to use the VGA passthrough of a Voodoo2 I also have installed, then the splash screen completely freezes and my PC outright resets after about a minute. I can still get into Windows 98 in safe mode.
This Windows 98 installation is almost totally fresh aside from the chipset drivers and PATCHMEM. I am using BootIt Bare Metal and it is the only OS installed so far, on a roughly 80 GB partition. The only other wrinkle I can think of is that I think I didn't correctly copy over files from the install CD the first time I installed and I had to use System File Scanner to retrieve some of them.
Has anyone had this issue with these drivers before? If so, are there steps to fixing them? Any advice is appreciated!
