First post, by Ikostra
Hello, I have recently acquired a Sony PCV-70 and a PCV-100. I need some advice from the experts here about what my options are with these machines. I think both have plenty of memory for retro machines of this type, but I'd like to upgrade the CPU as far as I can. Unfortunately, I can't see any mention of support for dual voltage CPUs in the motherboard specification and I see that the maximum multiplier is 3, which limits me to 200mhz. However, I was looking at the CPU specifications and I didn't see any MMX cpus that didn't use dual voltage. Does anyone know if this motherboard does actually support dual voltage, or how it is able to run an mmx pentium without it? What CPUs should I look for it I were to upgrade these machines? I see that the 200 and 233mhz mmx pentiums have similar voltage requirements to the 166 mmx, would they work (albeit limited to 200mhz?)
Both are functional, but were missing the hard drives (and drive covers) when I got them. They are both quite dirty and dusty and need a good cleaning. They have accumulated approximately 30 years of dust, and it looks like they haven't ever been cleaned. Also, someone wrote on the back of both of them in permanent marker. Nevertheless, I am very impressed by the build quality. The case design allows for toolless entry (swapping add-in cards still requires tools). They both seem to share the same motherboard design. I note that the motherboard has 0 electrolytic capacitors, which I'm sure helps with the longevity.
The PCV-70 has the standard 166mhz pentium still in it, but has been upgraded to 96mb of memory. It appears to have been used as a server or workstation at some point, since it was also upgraded with a scsi card, a video capture card, and ethernet. It's a shame the hard drives weren't included. These machines seem to have been kept in use for a long time and used for a variety of purposes.
The PCV-100 still has the standard 166mhz pentium mmx in it, but has been upgraded to 64mb of memory. It also has an etherneet card. It had a scsi card as well, but I removed it (extra boot time and I'm not using it).
I've been doing some research already. the motherboard matches the one on the retro web: https://theretroweb.com/motherboards/s/intel-ag430hx-agate
I found this page, which lists some information about the 70 and 90 model, but doesn't list the 100 or 120 models. https://vaiolibrary.com/PCV-**0
Wikipedia has an article on the PCV series, which does mention the 100 model. It seems it was released a year later than the 70. https://en.wikipedia.org/wiki/Sony_Vaio_PCV_s … es#cite_note-10
