First post, by rico001
Starting to test a JaiHo monitor that supports vga and is not crt like I am used to:
possible example: https://www.amazon.com/dp/B07DCC12ZH
So far it looked good on older 320x240 setup used a av2hdmi cable and didn't even hook up vga,...
I am hopping to maybe hookup a raspberry pi with an adaptor, 240p 15hz
or a a1200 mini pc n the future... Maybe lcd may be a smaller VGA solution for some than crt
still learning...
