First post, by Vivid Warthog
Hello everyone!
After switching from good old MT-32 to CM-64 I've started to miss the LCD display, so I've thought I'll try to fix that.
I've been prototyping an external screen for CM-64 in a self-contained module with midi through and the same power source the Roland devices use, so no CM-64 modification is necessary and no additional cables, except power splitter and short midi cable (between unit and CM).
I wanted the device to look like the an original addition to the unit, so I've added the same ribbed bar to the shell.
The case is 109.8 mm wide × 95.8 mm deep × 38.5 mm tall.
The unit itself uses RP2040 as its core that parses the sysex and midi commands the same way the MT-32 does (based on MUNT project code). I'm yet considering if CM-32P events should be displayed too, and if so, how 🤔
Once tested and when all issues are ironed out, I'll be sharing STLs, gerbers and firmware for DIY.
I'm yet waiting for v1 PCB to come from the factory to assemble and test the whole thing in full, but wanted to share and ask what do you think about the idea.
