First post, by Feanor_twh
I'm trying to add L2 cache to my PS/Valuepoint 466DX2/Si, as it's completely absent on this model (all the sockets are empty).
I'm very happy with this machine; once everything is properly configured, it works perfectly. However, performance is severely limited by the lack of L2 cache. I can't even run Doom, Heretic, or Strife smoothly.
It's a bit complicated because everyone says something different, and it's not clear exactly how many and what type of chips need to be installed. The board has ten DIP-28 sockets: four marked Cache 128, four marked Cache 256, one marked Cache TAG, and one marked Cache DB.
The only instruction on the sticker attached to the chassis is that you need to populate slots 1 to 6 for 128k and slots 1 to 10 for 256k. Since I'm going to do this, I'd like to go up to 256k.
Do I have to use all the same chips? Do the TAG cache and DB cache chips have to be different? Do I need to use both of these chips, or is the TAG chip enough? Also, does anyone know how to get these chips relatively reliably and what part number to look for?
Thanks.
The attachment WhatsApp Image 2026-11-18 at 7.01.44 PM.jpeg is no longer available
DOS - Amstrad PC1512 NEC V30 640kb 128mb CF XTIDE
Win3.1 - IBM PS/ValuePoint 486DX2 8mb Tseng ET4000 2gb CF
Win98 - AT 386 case K6-III 400 128mb Voodoo3 2000 20gb SSD
WinME - Intel Dot Station (Paquito) PIII 750 256mb FX5200 128gb SSD
Wrong setup? Lmk plz
