First post, by jonesmacarrones
- Newbie
Hey everyone!
I am sure nobody asked for this, but I vibe ported XCOM Enemy Unknown for the 8088 with Hercules, CGA, EGA, VGA, PC Speaker, Adlib and Sound Blaster support, all experimental but (I think) the game is playable to the end.
I spend a lot of time and tokens optimizing it to fit 640Kb and to run on a speed that can be considered playable on a 10Mhz 8088, this is the 51st interaction with more to come, specially with feedback.
My tests are mainly done on a real V20 with UMB and XMS running at 10Mhz, Adlib sound, EGA (on a VGA800) mode and monitor, and a bus mouse, should work with serial and PS/2 mice too.
For VGA and Sound Blaster you need at least a 286, is all listed on the manual.
I did not had the time to finish the whole game yet.
It uses whatever memory you have (UMB, XMS, EMS, Conventional only), its all in the manual but it needs as much conventional memory as you can have, it also has mouse support of course!
https://github.com/fmikowski/xcom-xt
Full disclosure: AI was heavily used in this project! No parts of the original game is shipped with the code, you need to provide your own copy and run a utility that is provided to convert it to the 8088 version, GOG, Steam or CD version should work (v1.4).
P166 MMX, 64Mb, S3 Trio64V+, Sound Blaster Pro 2.0 - DOS & W98
Athlon 1.3Ghz, 256Mb DDR, Voodoo 5 5500, SB Live! 5.1 0100 - DOS & W98
i5 3550 3.7Ghz, 16Gb, MSI GTX 980 Ti - WinXP & W7
5900X 4.7Ghz, 32 Gb, 3080 Ti FTW 3 - W11
