Won't Install on MacOS X
First post, by nothingforjuice
Hi,
Sorry to post a question from the get-out, but I went through the guide and search through old threads to no avail.
I'm on a PowerBook G4, OSX 10.3
When I download the sit, stuffit says, "An error has occured while expanding the file "DOSBox-0.63-1.sit (The archive may contain damaged content).
The folder it extracts to doesn't appear to have all the files, just the manual.txt and DosBox.app. the .app only opens in textedit. I tried doing it the roundabout command line way described in the guide, and I just get "command not found" when I type DosBox.
Also, I tried downloading the .sit on a different computer, 'cause I've know StuffIt to find errors where there are no errors, and I get the same result. Is the file bad or am I just doing something dumb?
I can post all my system specs if you like but that doesn't really seem relevant since I'm not getting past point 1.
Thanks.
