First post, by 16bitgium
Hi guys ,
I have a HydroThunder arcade cabinet wich is basically a Pentium 2 based PC.
I had trouble with my harddrive as it would no longer read the data correclty:
You can add a CF card but it doesn't accept CF cards larger then 8GB unless you update the BIOS.
Check this thread here :
https://forums.arcade-museum.com/threads/hydr … uestion.302317/
direct link to the download file
https://drive.google.com/open?id=1sKqQoHfAnvG … LTd1-AANf3dbK9b
Somebody made an automated bios updater serveral years ago, I ran it, it looked succesfull but now I only get a black screen , the diskette drive doesn't seek once but seeks continiously and the light is on continiously.
Things to note:
The included graphics card (Voodoo2) does not display the the BIOS only the ingame GFX. I need to use a seperate GFX card on the AGP slot to display bios and POST.
Anybody got any idea how to revive my motherboard? It is a standard Intel SE440 BX-2 but I'm not that PC savvy I always was a MAC/Amiga guy 😁.
I already took out the bios battery for several minutes. removed the BIOS jumper....
Reply 1 of 16, by zapbuzz
16bitgium wrote on 2026-11-19, 10:01:
Hi guys , I have a HydroThunder arcade cabinet wich is basically a Pentium 2 based PC. I had trouble with my harddrive as it wou […]
Hi guys ,
Things to note:
What has happened is you've flashed a bios image that wasn't programmed properly or not matching your motherboard (lots of amateurs out there) or the flasher
you used doesn't properly support your BIOS. I am thinking the flasher just ignored if the bios was correct or not thats why you must use official flashers fromt the BIOS company that come in version ranges to suit BIOS generations.
The floppy drive is doing its business because your BIOS is running in "bootblock mode" expecting a recovery floppy formulated in the following.
Now you need to get the OFFICIAL BIOS file and put it on a bootable DOS floppy ready to boot the official flasher app with bios file written to execute automatically on the AUTOEXEC.BAT so it will automatically flash the correct BIOS file without video monitoring. An official flasher is from the BIOS company usually comes bundled with the correct BIOS download archive.
Please remember in future that most your problems stated may be chipset limitations not the BIOS you only update the BIOS if the chipset has features proven to exist that your BIOS doesn't most BIOS are a match! Also there are GPU's that will only show their screens in specific hardware configurations to compliment marketing ploys across limited supported ranges but usually still work fine.
Your disk capacity issue can be solved with a dynamic drive overlay it uses a small amount of system RAM.
Reply 2 of 16, by PC Hoarder Patrol
Follow the attached readme to make yourself a clean BIOS boot disk with the attached P17 update
The attachment README.TXT is no longer available
The attachment se2bio17.exe is no longer available
Then follow the section of the attached extract from the manual entitled 'Recovering the BIOS"
The attachment se440bx-2 BIOS Recovery.pdf is no longer available
Reply 3 of 16, by 16bitgium
Hi,
Question: Can I use an USB keyboard or does it need to be PS/2 ? Or can I use a PS/2 to USB adapator?
Reply 4 of 16, by 16bitgium
And thanks for your comment!
Reply 5 of 16, by Repo Man11
16bitgium wrote on 2026-11-19, 15:12:
Hi,
Very little chance it will detect a USB keyboard in Bootblock mode so definitely use a PS/2 keyboard or adapter. These instructions may also help as they have an example of what you want the autoexec.bat to look like. This may work, but sometimes even if you do everything to the letter bootblock recovery will fail. If that's the case you'll have to buy programmer or send your chip off to someone to be reflashed.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 6 of 16, by rasz_pl
as zapbuzz noted 'diskette drive doesn't seek once but seeks continiously and the light is on continiously' means almost 100% sure bootblock recovery is working. You wont need keyboard for anything in that case, it will automagically load and flash bios
other options for flashing bios are local hackerspaces, or hotswap method with another mobo using similar Bios chips.
Reply 7 of 16, by 16bitgium
I tried yesterday, but failed again.
If i insert the original disk created for upgrading the bios ? I hear the disc working but it ends in continiously rapid low beeps which go on forever. Which means i guess update failed.
I turned to gemini for help (sorry I was desperate 😀
Based on my serial number GTS285167183 AA 720940-209 gemini claims that I should have Micron bios. But I distinctly remember seeing the Intel splash screen when booting up:
I tried the Micron bios anyways but nothing happend ,disk was accepted and spins for a while but then just stops.
Then Gemini claims the following, IS this correct?
Making the floppy a "bootable disk" is why the recovery kept beeping. The SE440BX-2 boot-block loader does not boot into DOS; instead, it looks at the very first sector of the floppy disk (Sector 0) and expects a plain, non-bootable FAT12 disk containing only the BIOS recovery files.
How to Create the Recovery Disk Properly
1. Format Without System Files:
• On a Windows PC, insert a 1.44MB floppy, right-click A:\, and choose Format.
• Leave "Create an MS-DOS startup disk" UNCHECKED.
• Use Quick Format (or full format) with FAT file system so the boot sector stays clean.
2. Copy the Extracted Micron (05A) Files Only:
• Copy all the extracted BIOS files from the Micron 4S4EB2X0.05A.0016.P15 archive onto the root of A:\:
• 4S4EB2X0.05A.0016.P15.BIO
• 4S4EB2X0.05A.0016.P15.RCV
• FLASH.EXE (or IFLASH.EXE) and any .DAT/.LNG files included in that same folder.
• Do not put COMMAND.COM, IO.SYS, MSDOS.SYS, or AUTOEXEC.BAT on the disk.
3. Run the Recovery Again:
• Ensure jumper J8A1 is completely removed (no pins bridged).
• Insert the clean, non-bootable floppy and power on the board.
• Instead of immediate error beeps, the floppy drive light should stay on and read intermittently for 2 to 4 minutes, ending with two confirmation beeps when the flash finishes.
Try formatting the disk without MS-DOS boot files using the Micron 05A files and let me know what happens after 2–3 minutes (whether it stops beeping and finishes with two long beeps, or still gives an error pattern).
Reply 8 of 16, by 16bitgium
The manual for the SB440 states :
NOTE
BIOS Recovery cannot be accomplished using non-SPD DIMMs. SPD data structure is required
for the recovery process.
https://nylan.info/SE440BX2/pdf/72163201.pdf
this might also be an issue , i'll have to check the ram stick tonight
Reply 9 of 16, by rasz_pl
Yes, bootblock recovery expects plain filesystem with bios in root directory. The problem is knowing which filenames it will look for. If you flashed wrong firmware you might have overwrote whole flash chip meaning now you have bootblock for wrong board.
easiest to just flash bios chip in programmer/another board
Reply 10 of 16, by 16bitgium
rasz_pl wrote on Yesterday, 11:44:
Mmm that means desoldering the entire SMD chip from the mobo ? The thing is the bios should actually be the correct one for this board.
Might it be cheaper to just purchase another SE440 BX-2, instead of looking around for a person who can flash this for me?
Reply 11 of 16, by H3nrik V!
I wonder if that arcade cabinet used a non-standard BIOS, and the one you've flashed is a standard Intel BIOS, and that is the reason why it doesn't work?
Did you already try another graphics card to see if anything is displayed?
Reply 12 of 16, by zapbuzz
16bitgium wrote on Yesterday, 12:06:
The chip is probably right but not what's in it and the intel SE440 BX -2 is rare.
Yes you would need to desolder the chip and program it with a tool but if you replace the board the prices are so expensive for your intel SE440 BX -2 it would most likely be much cheaper to find someone to program your chip for you or learn how to DIY which would save hundreds.
Reply 13 of 16, by 16bitgium
But how would I know which BIOS is correct ? I shouldn't have been this impulsive..... I bougth a replacement mobo on ebay for 100 euro including shipping. Hopefully that one will work.
Reply 14 of 16, by rasz_pl
oh right this is Intel board so they used Intel e28f004s5 in TSOP 40, needs lifting with hotair and $10 adapter board to flash https://www.proto-advantage.com/store/product … ucts_id=2200238
or even something as ghetto like this https://www.ebay.com/itm/147678332694 and soldering 40 wires to spare dip40 socket
Thats more than XGecu T48 + tsop40 adapter + hotair station + spare e28f004s5 + some soldering supplies 😀 or going to hackerspace and asking for help in person.
tell me about it! 😀
Reply 15 of 16, by PC Hoarder Patrol
16bitgium, did you actually prepare and try the BIOS boot floppy I described above or did you just retry your original update disk?
The Quantum3D Quicksilver II system used in HydroThunder arcade cabinets uses a standard Intel SE440BX-2 motherboard and associated Intel BIOS, the latest being confirmed as P17 by Quantum3D themselves (https://web.archive.org/web/20001109204100/ht … /Qs2/Index.html) and is the exact one I attached above.
If the Intel recovery procedure I detailed subsequently fails then the problem lies elsewhere.
Reply 16 of 16, by 16bitgium
Yes the only difference i did was I created the bootable disc in Windows xp itself and then removed the System files from the disc for Space. because I couldnt get the command format a: /s to work in my Windows xp pc.
