First post, by Karbist
Karbist
Offline
I have this FX 5200 card with 128MB/64bit memory: https://theretroweb.com/expansioncards/s/prol … vg34aplus-128mb
since the component for additional ram chips were already populated, I added 4 more ram chip to make it 256MB/128bit.
then I had to adjust one strapping resistor to change memory config from 64bit to 128bit.
now memory is detected as 128MB/128bit, if I flash the bios with 256MB version of FX 5200 or any FX 5500 bios, memory is detected as 256MB/128bit.
I wonder if it's possible to modify the memory size in bios so I can use the original bios?
