First post, by priesT
Perhaps its just me not knowing the DOS commands very well but I can't seem to be able to execute the file.
I mount c c:\guest (the folder where the game files are saved)
then when everything is mounted, I try and execute t7g.exe but this appears
c:\guest\t7g.exe
c:\guest\win t7g.exe
Illegal command: win
Can anybody tell me why? and how to fix it
Reply 1 of 3, by Lofty
It's trying to load windows up. I did a quick google search and it looks like there's both a DOS and Windows version of 7th Guest. Are you sure you're running the right version? Check for other .exe or .bat files in the 7th guest directory. If only t7g.exe exists, maybe you only have the windows version?
Reply 2 of 3, by priesT
I tried looking it up, and I only found one t7g.exe. However it still doesn't work when I execute it on windows
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
What does it say then?
