First post, by Unregistered
I need help with a new installation of VDM Sound in Windows 2000. The problem occurs right after hitting the next key in step wher the installer is ready to begin the installation of VDM sound on your computer. The error says the installer has been interupted and you need to restart the installation. I get this error every time.
email: popsgivens@aol.com
Reply 1 of 1, by Snover
This has been documented. YOU MUST RUN THE INSTALLER AS AN ADMINISTRATOR. Use the search, too. It's not hard. You type in a few key words describing your problem, like, for example, "VDMSound won't install" and then you'll find threads regarding VDMSound not installing. It's just another incredible piece of technology. Also, we do not send messages to email addresses. If you want to get an email, register with the forum and choose to receive messages when you get a reply to a thread. Closing thread: DUPE
Yes, it’s my fault.
