First post, by Jiri
This game works fine in 0.63, but in the latest CVS build it crashes on exit with error "FATAL MIDAS uninitialization failure: Invalid conventional memory block" and then it always freezes on start after the intro. Also mouse does not work correctly in windowed mode with autolock=false. I have tested it with the full CD version and also with the game rip from HotU that behaves similarly (only there is no intro).
