First post, by zvrastil
Hi, I was using DOSBox 0.63 on Debian Sarge without problems for some time. However, after upgrading SDL library through apt-get to version 1.2 (package libsdl1.2debian), the Shift key is no longer working in DOSBox. I can write lowercase characters, with CapsLock also uppercase character, but no special characters (most missing the ':') - when Shift is pressed, no other key responds.
Reply 1 of 10, by wd
Rank DOSBox Author
DOSBox Author
You could try a CVS build of dosbox, there you can set
usescancodes=true in dosbox.conf (might help).
Reply 2 of 10, by zvrastil
Thanks for the advice. Any chance to get the CVS build anywhere but from http://cvscompile.aep-emu.de/dosbox.htm ? This page does not seem to work. But maybe, it's just some temporary problem - I will continue trying.
Reply 3 of 10, by eL_PuSHeR
Try Ykhwong´s build. I think it's has been updated a few days ago.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 10, by zvrastil
CVS build with following in the dosbox.conf:
[sdl]
usescancodes=true
works perfectly. Thanks a lot.
Reply 5 of 10, by wd
Rank DOSBox Author
DOSBox Author
Did you update SDL only, which broke the keyboard, or could it
be something else?
Reply 6 of 10, by zvrastil
I was using dosbox from debian distribution. There was probably also some older libsdl version installed, but I'm not sure which one. Two days ago, I was compiling qemu from sources, because of some problems with debian version. For that, I needed development package of libsdl. Only one available was libsld1.2-dev, so I apt-got it. Apt-get removed some old sdl library (I don't remember which one) and installed whole bunch of libsdl1.2 packages. After that, Shift key in dosbox stopped working. I'm pretty sure I did not installed anything else.
Hope it helps. If you need some more info or help from my side, feel free to ask.
Reply 8 of 10, by zvrastil
Definitely not. I'm using X.org, but it has been at least three weeks from last atp-get dist-upgrade (during which X were probably upgraded). I'm using dosbox almost each day now, so I discovered the problem immediately. I'm sure there was no other upgrade than sdl upgrade, between working-not working state.
Reply 9 of 10, by wd
Rank DOSBox Author
DOSBox Author
Are you using a non-US keyboard layout in linux?
If so, maybe you could try to see what happens if
you switch it to the standard US one (should work
with usescancodes=false then as well).
Reply 10 of 10, by zvrastil
I'm afraid this is not cause of my problem. I'm using three keyboard layouts in linux - US, Deutsch and Czech. The US layout is the default and I'm using it unless I'm creating some document.
However, to check it, I switched off the layouts in xorg.conf, so only US was available. However, the Shift key behavior is still the same, without "usescancodes=true".
I did some more testing and this is the description how exactly it works:
- without Shift pressed, all keys work as expected
- with Shift pressed, letter keys work (writing capitals). Also, keys / * - + on numerical keyboard do their job.
- no other "character" key works with Shift pressed (numbers on both normal and numerical keyboard and all special characters). nothing happens, when I press the keys.
- there is one strange exception, key ',', instead of producing '<' character produces '|' (pipe) character when Shift is pressed
