First post, by Hamlet
hello!
nice to meet you all, especially those of you who are able to help me with this one little problem ive been having.
Well its with the game Sam n Max, you remember it, im sure. I've tried all the things i could think of and read all that i could find that might help, but nothing, i still get only the music, while the voice and fx remain disabled... i checked in the game, they say "disabled"... well im not a very smart guy, so now i bring it here and hope someone can find a way to help me.
here are some stats.
im on an ibm notebook sporting an intel (R) pentium (R) M 1.60 GHz and 248 mb ram, its got a SoundMAX Integrated Digital Audio sytem, whatever that means and using integrated speakers, my computer uses windows xp profesional which it came with and im running the game through dosbox 0.63. The game as said before is Sam n Max Hit the road, and well i dont know what they call the version, but its a newer version that came with day of the tentacle on one cdrom and apearently also the first maniac mansion game integrated into game (day of the tentacle), i have run day of the tentacle, played it all the way through and had no problems with it at all, have only had problems with sam n max. Sam n max, unlike day of the tentacle can be run without the dosbox, through windows but then without sound at all, i also found that running it with the dosbox emulating sbpro as it was by default set to also gave no sound at all, however changin this to any of the other sound cards gave me music, but like i said, still no sfx or voices, they remain disabled, while i get no error message.
I tried reading the games manual, which told me that i had to set up the games sound which could be done by entering the configurations menu in the main menu, which i should see when opening the game, this however is not the case, the game starts emediately without letting me set it up... i have tried changin the soundcard emulation in the dosbox, however with only that half luck. i have tried reading every manual, every readme file, infact anything writen i could find that might hold the answer, even all the stuff online and in this forum that i could find, but nothing have seemed to help... the problem now persists and i dont know what to do, please help.
the following is a copy of my dosbox config file, as is, in case you need further information from that.
Thanks...... hamlet
[sdl]
# fullscreen -- Start dosbox directly in fullscreen.
# fulldouble -- Use double buffering in fullscreen.
# fullfixed -- Don't resize the screen when in fullscreen.
# fullresolution -- What resolution to use for fullscreen, use together with fullfixed.
# output -- What to use for output: surface,overlay,opengl,openglnb,ddraw.
# hwscale -- Extra scaling of window if the output device supports hardware scaling.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
# priority -- Priority levels for dosbox: lower,normal,higher,highest.
# Second entry behind the comma is for when dosbox is not focused/minimized.
# mapperfile -- File used to load/save the key/event mappings from.
fullscreen=true
fulldouble=true
fullfixed=true
fullresolution=640x480
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory dosbox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=16
[render]
# frameskip -- How many frames dosbox skips before drawing one.
# aspect -- Do aspect correction.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,advmame2x,advmame3x,advinterp2x,interp2x,tv2x.
frameskip=3
aspect=false
scaler=normal2x
[cpu]
# core -- CPU Core used in emulation: simple,normal,full,dynamic.
# cycles -- Amount of instructions dosbox tries to emulate each millisecond.
# Setting this higher than your machine can handle is bad!
# cycleup -- Amount of cycles to increase/decrease with keycombo.
# cycledown Setting it lower than 100 will be a percentage.
core=dynamic
cycles=2500
cycleup=500
cycledown=20
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
# probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
# but sound will also be more lagged.
# prebuffer -- How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=2048
prebuffer=20
[midi]
# mpu401 -- Enable MPU-401 Emulation.
# intelligent -- Operate in Intelligent mode.
# device -- Device that will receive the MIDI data from MPU-401.
# This can be default,alsa,oss,win32,coreaudio,none.
# config -- Special configuration options for the device.
mpu401=true
intelligent=true
device=default
config=
[sblaster]
# type -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.
# base,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.
# mixer -- Allow the soundblaster mixer to modify the dosbox mixer.
# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3.
# On auto the mode is determined by sblaster type.
# oplrate -- Sample rate of OPL music emulation.
type=sb16
base=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
# gus -- Enable the Gravis Ultrasound emulation.
# base,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the
# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)
# rate -- Sample rate of Ultrasound emulation.
# ultradir -- Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=true
rate=22050
base=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# Tandysound emulation is present if machine is set to tandy.
# disney -- Enable Disney Sound Source emulation.
pcspeaker=true
pcrate=22050
tandyrate=22050
disney=true
[bios]
# Nothing to setup yet!
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
xms=true
ems=true
[modem]
# modem -- Enable virtual modem emulation.
# comport -- COM Port modem is connected to.
# listenport -- TCP Port the modem listens on for incoming connections.
modem=false
comport=2
listenport=23
[directserial]
# directserial -- Enable serial passthrough support.
# comport -- COM Port inside DOSBox.
# realport -- COM Port on the Host.
# defaultbps -- Default BPS.
# parity -- Parity of the packets. This can be N, E or O.
# bytesize -- Size of each packet. This can be 5 or 8.
# stopbit -- The number of stopbits. This can be 1 or 2.
directserial=false
comport=1
realport=COM1
defaultbps=1200
parity=N
bytesize=8
stopbit=1
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
mount c c:\
mount d d:\ -t cdrom
thanks again
Reply 1 of 2, by collector
Try the game with ScummVM
Reply 2 of 2, by Hamlet
thank you very much, yes it works perfectly... well i havent played the whole game yet, but from what i can see i have no reason to beleave that it will give me any trouble at all... when i think of the time i have spent trying to fix it, and downloading that and setting it up to run took me all of two minutes... thanks again
Hamlet
