First post, by davedave
Hi.
I tried this with DOSBox v 0.65 and 0.63 and both have the same problem.
When I load up DOSBox, it displays two windows. One with the background information and one which is supposed to be the DOS window. The DOS window doesn't display anything for around 20-30 seconds, then the prompt shows up. If you type anything it takes another 20-30 seconds for the text to appear. This makes it kind of unusable. :)
Athlon 64 +4000
Abit KN8 Series
2 GB DDR
GF7800 GTX 256MB
SB Live!
XP SP2
I've tried playing with CPU settings (clock cycles, cpu mode) but that hasn't made any difference and I've also tried turning off sound in the config file. Neither have helped.
Any help would be appreciated.
Dave.
