First post, by Dragoon42
How do I make DosBox use /dev/joy0 as my joystick? Currently it uses uhid1 which is an attached keybad on my Saitek Gamer keyboard. I'm using FreeBSD, but if you're familiar with Linux I can try those suggestions too!
Reply 1 of 2, by iampiti
AFAIK dosbox gets its input through SDL so maybe you shoud check the sdl docs.
Sorry not to be more specific I'm just too lazy 😀
Iampiti
Reply 2 of 2, by Dragoon42
That's more info than I had. Thanks! I'll go start reading.
