First post, by Matt81
Hello, I have recently been looking into using dosBox to run an old application that never got supported by windows newer than win98. The application is for data capture - the card is ISA. I've recently purchased a PIV 3.4Ghz, 1Gb RAM, with ISA slots. I have the win98 drivers, and I'm sure there are dos drivers available too - firstly I'm not sure which ones to use. Although my main question is how do I load these into dosBox? I'm pretty certain I'm meant to edit the dosBox.conf file, but I do not have any knowledge of the language involved in editing this. My front end OS is XP. Failing using dosBox, I'm considering using VMware and running pure DOS or win98 through that in order to access the ISA. Any help & direction would be much appreciated,
- Matt
