First post, by fedorov
hi guys...i duno if this is a technical thing or...
i cant seem to get the required potion to deal with the lich. i plugged in all 3 of the potions and the empty vial to the apparatus...on the fire...but nothing happens...
is this a known bug in U7 or am i missing something?
Reply 1 of 4, by avatar_58
Its been awhile, so I consulted the UHS page:
"Go to Mordra's place and take the three potions she mentioned:
red (antidote)
black (invisibility)
glowing (mandrake).
Go to alchemists' and take the fourth (empty) vial.
Place the potions and the vial beside the burner.
The caps of the bottles should be covered by the nozzles of the burner.
Then, turn it on (double-click on its center).
If it doesn't work, one of the potions is out of place.
It doesn't matter in which order you set them, but the empty vial should be at the separated tube."
http://www.uhs-hints.com/uhsweb/hints/ultima7/776.php
Make sure they are lined up PERFECTLY and that each is the right potion type.
Reply 2 of 4, by eL_PuSHeR
Changing topic title to something more "intuitive" and moving to Milliways
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 4, by fedorov
thnx. will try again...its really strange...
Reply 4 of 4, by avatar_58
Let me know. If it is still doing it, take a screenshot showing the potions and empty vial under the device. I just want to make sure its setup right.
