First post, by petro
Hello,
i must use ctrl+c to exit an application, i use dosbox 0.65.
Did anybody know if this is possible to use in with dosbox.
thanks
petro
Hello,
thanks
petro
if you tried it and it didn't work then it doesn't work 😀
you can use ctrl-f9 to exit dosbox though.
Water flows down the stream
What is the application name?
Ctrl-C is not handled. (EDIT->oops.. I meant ctrl-c flag)
Try to boot DOS image in dosbox.
Of course ctrl-c is handled, just the dos input routines don't check
for it, and it doesn't issue an int.
Hello,
i know ctrl-f9, but i must end the application (with ctrl+c) , start an editor, do some changes and start the application again, all in the same dosbox.
thanks
petro
wrote:i know ctrl-f9, but i must end the application (with ctrl+c) , start an editor, do some changes and start the application again, all in the same dosbox.
About what editor are you talking?
Can it be that you mapped the key for another purpose?
That won't work, those games/programs intercept an int which
is not present and can't be added easily.
Hello,
OK, if you tried it and it didn't work then it doesn't work. I can live with that.
It is only a little compicated to use.
thanks
petro
