First post, by ratfink
I've got an old Gravis Ultrasound ACE, where the ACE means Audio Card Enhancer. It's supposed to work with Sound Blasters, and I've put mine in a system with an SB16 [CT1740 I think].
The GUS software crashes when I try to set it up. I'm assuming this is a hardware conflict, but running "install" from the Gravis CD sets in chain a process of copying CD software to hard drive, and then running a configuration program - for setting IRQs, DMAs, etc. I've disabled the printer port so I can use IRQ7, and DMA3 is free. But when I confirm the settings, the computer freezes.
I'm running Windows 98 - I suppose that could be the problem.
Any ideas?!
