First post, by SolaceEternal
I appologize upfront if this is something that has been discussed before and I overlooked it; it's quite possible that I'm just an idiot.
However every game I play in dosbox results in the graphics skipping and lagging. Mouse pointers skip around the screen, button clicks take a few secconds to register, so on.
That being said, I'd like to point out that it's not my computer making the lag; my system was built for graphics (games, 3d-modelling, artwork, etc) and dosbox's memory useage is minimal at best.
I'm usin' windows XP.
Games I've tried:
High Seas Trader
Lords of the Realm
Master of Magic
Settlers 2 Gold Edition (just running it in XP works better than dosbox, actually)
Pizza Tycoon
...bit of an unrelated note. I can't get "The Horde" to work at all.
Reply 1 of 2, by SolaceEternal
Forgot to mention: "overclocking" it (ctrl F12, whatever you wanna refer to it as) doesn't seem to help.
Reply 2 of 2, by avatar_58
What are your PC specs? Cpu speed? Dosbox uses quite a bit of resources, despite what you would think.
Depending on the games, you may need to increase the cycles as the default 3500 will only work with the oldest of games. You also should try running in the 'dynamic core' instead of normal. You can setup all this stuff in the dosbox.conf just so you know.
