First post, by WhiteKnight
Hello,
Is there a way to change the Z drive default in DOSBox to another letter, such as X: or something else? Is it part of a config file or something?
Thanks in advance for your feedback!
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
No, besides changing the sources.
Reply 2 of 4, by red_avatar
I wondered the same thing a while ago because it seems Windows 3.1 had this thing where it shows all drives at the top of Winfiles regardless of if they exist because of the Z drive.
Reply 3 of 4, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
red_avatar wrote:
...it seems Windows 3.1 had this thing where it shows all drives at the top of Winfiles ...
This may be fixed in CVS. I am not sure, I did not test it, but I read somewhere about one HAL's patch recently commited to CVS which may influence this.
Mirek
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
yeps that part was fixed.
I was thinking of making the Z:\
easier configurable when compiling DOSBox. Although there isn't a game that needs it. (except for a few bad cracks maybe)
Water flows down the stream
