First post, by Unregistered
I'm using the launchpad for VDMSound. However, though the setup seemed quite fine for this tool, when it omes to execution, i come up with errors like
"Unable to instantiate emulation module '**each module here, in seperate error messages**'
**some memory address** - Invalid class string(c:\**strange, the windows' temp folder is here**\~something.ini:**two digits here**)
Do you want to continue?"
after I say yes for each module, a brand new one comes up:
"An error was encountered while attempting to load and display the Tip of the Day:
Last error reported by windows:
**some memory address here** - The specified module cannot be found.
The initializing process will now continue."
after this point the execution goes on and the game works fine, except the sounds and the music. did i install the launchpad in a wrong way or something?
