First post, by ratfink
This may just be my bad memory, wonder if anyone knows better.
Just got a 5.25 floppy drive, works fine but....
- it doesn't eject disks when you open the latch - I can't remember if they used to. Just wondering if mine is bust or if that's how they were...? Feel weird not knowing cos for a few years I ran a two-floppy, 5.25 no-HD system where I worked!
- you feel friction on the disk as you insert and pull it out. Is that normal? I don't remember this, but I do recall 3.5's seeming just so-o-o much better so maybe this is also normal.
