First post, by halfgaar
- Newbie
Hi,
Psycho Pinball works almost perfectly in Dosbox, but I have this very annoying problem with the vertical tilt. Whenever I press space (to tilt), the screen currupts a bit, and most importantly, it releases all my pressed keys, including the tilt itself, meaning you can't tilt very high.
This takes away the ability to perform one of my most important strategies, which is to throw the ball back into the table when it is about to roll off via the sides. To to this, I hold up the flipper on the respective side, and press vertical and the proper horizontal tilt keys simultaniously. But, because the vertical tilt causes my keys to be reset, the ball is slammed right down again by the falling flipper.
Is there a way to fix this?
