First post, by Przemcio241
Hi i own 1,2 GHz Athlon with 512 mb Ram and i have problems with running those two games under VDMS it seams that they need some kind of memory or something 😢 can any one tell me how to run those games??? i will be veary greatfoul...
PS i don't remeber much about DOS&memory stuff this was so long ago and those games can be obtained on the Underdogs or any other such site...
BTW when i try to run Pacific Strike another Flight Sim i get the following message EMS Driver is not VCPI Compilant is there something i can do with it???
Reply 2 of 13, by Przemcio241
yech but it works kind of wierd.... not a full screan and such 😒
Reply 3 of 13, by eL_PuSHeR
You should read the guides in the DOSBox guides section of the forum.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 13, by Przemcio241
Thank i got it now not a perfect layout and the game runs a bit slugish but will do for now...
Reply 5 of 13, by collector
Przemcio241 wrote:
...the game runs a bit slugish but will do for now...
Did you increase your cycles?
Reply 6 of 13, by eL_PuSHeR
And did you use dynamic core?
*** Moving to DOSBox Games/Apps. sections because I take you are now using DOSBox ***
Intel i7 5960X
8 GB DDR4 (2100)
Reply 7 of 13, by mglsharkson
Okay I finally got aces pacific to work in dosbox - had to look on the web and found the magic dosboxconfig settings (cycle 1000, up / down 250, frameskip 1 mem 32, dynamic core if memory serves me right) to make it work.
Now I like to add the 1946 add on / upgrade from underdogs. No readme or notes are included. The 1946 upzips then I then copy all files unzip to aces dir. I run patch - It asks for dir of PATCH.RTP file which I cannot find anywhere. I do still have the orginal disks f/ docs for both games so I can try to run the '46 upgrade from disc. The orginal doc's I do have say tell the '46 add on where to instal to.l
Any ideas, gang?
M
Reply 8 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
sorry no abandonware supported here.
Try your luck elsewhere
Water flows down the stream
Reply 9 of 13, by mglsharkson
Any suggests where to go?
M
Reply 11 of 13, by joeb1234
Any one able to tell me how to get the game running in DosBox. I use d-fend as a front end.
