First post, by Meskalinka
I have game Fragile Allegiance and i have a problem with fakecd :
if game work i must use fakecd program:
fragile.bat > fakecd c:\fragile /L:K
fragile.exe /s <
fakecd create cd at local drive K but not in dosbox. When i launch fragile.bat in dosbox i see message from fakecd
> fakecd 1.0
You do not have enough drive letters available.
You must include (or replace an existing LASTDRIVE-) line
LASTDRIVE=K
in your config.sys.
You may replace K with any letter that comes later in the alphabet.
fakecd has NOT been installed. <
i try to find someting like config.sys but i cant find this file.
mount k c:\fragile < dont work
mount k e:\ < when e is the real cd game dont work too
i try to use dosbox because in windows XP i have only 60Hz 😒 and i cant launch this game in window
yeah i have a choice to start this game in VirtualPC with Windows 98 but this is to much work.
can anyone help me with this problem?
sorry for mistakes but my english is not good
Reply 1 of 2, by eL_PuSHeR
FAKECD isn't needed inside DOSBox. Edit the batch file and put a REM statement at the starting point of the line that loads FAKECD, something like:
REM FAKECD .....
Then, inside DOSBox:
mount c c:\whatever
mount k c:\fragile -t cdrom
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by Meskalinka
it's work!!!! thx a lot el_PuSHeR
