First post, by b.driesen
Hi Forum,
we use the DOSBox for an old DOS application, which uses old CGA graphics. This works realy great, but we have a small problem with the print output.
The program prints only to LPT1, so we use the NET USE command, to redirect the LPT1 to a network printer. I can see the printjob in the queue from Windows, but the printer starts first, when I stop the DOS application.
Can I set a timeout somewhere, so that the printer starts after for example 5 seconds without receiving any data?
Thanks for your answers,
Bernd.
Reply 2 of 16, by eL_PuSHeR
I think you need to send PCL or PostScript data (depending on printer's installed personalities) to printer in order to properly print while redirecting LPT1 via "net use" is in effect. That's why I love my HP LS1200, because it has a common parallel port for communicating with the PC. I really hate using USB for printers. It's just PLAIN STUPID, because it breaks backwards compatibility and parallel port has always worked fine for printers. USB is nice but for anything else.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
send an email to the address listed on dosbox.sf.net/crew.php
stating your poblem. We might be able to help you with some experimental stuff
Water flows down the stream
Reply 6 of 16, by jal
Yeah, except USB is like a gazillion times faster, and almost noone needs backwards compatibility. I like my USB printer just fine.
JAL
Reply 8 of 16, by jal
eL_PuSHeR wrote:
But do printers really take advantage of USB speeds?
Furthermore, do they need it?
My budget model, 3 year old, Samsung laserprinter is about 5-10 times faster when I print via USB than via LPT. Modern printers can process data faster than the LPT port can deliver.
JAL
Reply 10 of 16, by jal
h-a-l-9000 wrote:
The sad thing is that USB printers don't use a standardized printing protocol... they all do the same thing but every model needs another driver.
True, but that also goed for parallel connected printers. Remember the myriad of printer drivers that came with WP5.1, for example?
JAL
Reply 12 of 16, by jal
h-a-l-9000 wrote:
But a lot of those could still print simple text sent to LPT1 for instance.
True, but that's just because of the OS's (DOS) LPT1 device, or the BIOS functions. You'd never send text directly to the hardware port, or would you? Same with USB printers, I can just use OS functions to access them, and even send plain text.
JAL
Reply 13 of 16, by DosFreak
I think you do a "name of command" > PRN but I'm not sure. Don't have a LPT printer to test it with.
Make your games work offline
Reply 15 of 16, by jal
mirekluza wrote:
Yes, it was like this.
Mirek
My point is, this is hardware abstraction by the OS. And it has very little to do with low-level access to printers. HAL9000's original remark about USB printers ("The sad thing is that USB printers don't use a standardized printing protocol... they all do the same thing but every model needs another driver.") is really about missing OS support (or at least, printing via the file interface support), and I do not see any difference there between parallel and USB printers (except for the parallel port, regardless of printers, having just that support). One would like to have a 'USBx' (where x is 1-number of USB ports) device, so you'd be able to type 'type somefile.txt > USB1', or something
JAL
