First post, by dnwllnghm5
I have Windows XP Home addition and I cant get HELL: A Cyberpunk Thriller to run on my system. Its A Dos game made in 1995. any thoughts on how i can get it to run??
Reply 2 of 10, by dnwllnghm5
ive tried using the program capibility wizard to change the load up settings to use win95/98 on the program and that dident work. I know that XP doesent allow me to use dos without xp running so i downloaded a DOS emulation program..i think it was dosbox. but i dont know how to use it.
Reply 3 of 10, by Snover
Compatibility modes are for WINDOWS GAMES ONLY.
Please read the posting guidelines. I was going to try to be nice and see if you'd give me more information without needing to tell you to since you filled out profile properly, but apparently not.
Also you did not answer the two other questions I had.
Yes, it’s my fault.
Reply 5 of 10, by prismra
RESURECTION!!!
Had any headway been made with this. I also cannot get this game to work.
I notice that when the game is run with DosBox, the game returns an error stating that you have 0k video ram available and you need 512k. Wich is hillarious considering I have 64 MB. I'm guessing that the game is somehow unable to address any of the vid memory due to the built in vesa driver it uses. I notice on the CD that there are other vesa drivers to try, however, I don't see how they could be used in XP...
Rocking the following:
Roland MT-32
Roland SC-55 Sound Canvas
Reply 6 of 10, by eL_PuSHeR
Try running it directly from a windows dos box (not the DosBox emulator) without music and sound first. Also, try selecting 640x480x256c video mode as preferred resolution (if there are more video modes available in game's setup). Tell us how it went.
