First post, by Victor Warner
Using version 0.63 under Linux (Linspire 5.0.347).
Have set in dosbox.conf fullscreen=true, fulldouble=true,fulfixed=true, full resolution=1024x768.
But the text still stays the same size as if doxbox running as a window.
Since I wish to see doxbox is a suitable replacement for dosemu I would like to know whether the size of text can be altered (which can be done in dosemu using different font files.
Help with this would be gratefully received.
Victor Warner
