Coms Problem
First post, by bean12345
How do you configure a com port if its to be used with a null modem cable?
Reply 1 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Like every other directserial connection. If that doesn't work for you then you can try out my nullmodem patch (either here in the patches section or on my homepage). It's directserial is improved and it can also simulate a nullmodem connection over network.
1+1=10
Reply 2 of 7, by bean12345
The program I'm using is a programmer. The unit in question goes into program mode but I'm unable to send and data to it, any ideas. Hal your patch did improve things slightly before your patch I couldn't even get program mode
Reply 3 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Does the Dosbox status window say anything unusual?
1+1=10
Reply 4 of 7, by bean12345
Yes it says Serial2 Errors occurred framing 0 parity 0 overrun (various no's as it retries) and break 0. Hope this means something to you I've no idea
Reply 5 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Tried to make Dosbox go faster? (cycles, dynamic core)
1+1=10
Reply 6 of 7, by bean12345
Anything over 8000 resets the unit I'm trying to program
