First post, by Rayek
I've never encountered this problem before I switched from XP to 2000. Now, after I mount a folder and navigate to start a game, and finally start one, nothing happens. Well, not nothing, the blinking underscore still blinks, but other than that... Nothing. I've tried several different settings (within reason), different games and programs, and even different versions of Dosbox.
I apologize if this has been asked or covered before, I'm very new here (2 minutes...) I am not new to Dosbox, and I am definitely not new to Dos, which is why this is especially troubling.
Reply 5 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
you may want to download the debugger version of dosbox (it's in the development forum)
to see if there are any weird lines in there. (at least copy the last lines after executing something to here
DOSBox debugger
Water flows down the stream
Reply 7 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
right.
create a configfile with debugger version of dosbox
(start dosbox
config -wc dosbox.conf
exit)
look for the line log= inside the file
set it to
log=c:\keen.txt
save.
start dosbox
start keen
exit dosbox.
attach the logfile here.
The unhandled interrupt shows that dosbox is doing something.
Reply 8 of 19, by Rayek
Here's the logfile, I let the message run a bit before I close, but it's repeating the same message.
    keen.txt
    483.62 KiB
    134 downloads
    The logfile
Reply 10 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
917687: EXEC:Execute keen1e.EXE 0
917687: FILES:file open command 0 file keen1e.EXE
917696: CPU:Illegal/Unhandled opcode 63
after 9 instructions it allready goes wrong.
That is really fast.
Reply 12 of 19, by wd
Rank DOSBox Author
DOSBox Author
Do you know how to use the debugger? I think on the dev forum
there's a short explanation somewhere.
Switch to the keen directory, and type "debug keen.exe" or whatever
the executable is. Please make a screenshot of the debugger window.
Press f11 three times, watchingm the disassembly. Make a screenshot
again. Repeat this once, and press f5 then.
Please post the screenshots here (.png preferrably) and tell if the
game crashed differently.
Reply 13 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
you might want to run a systemcheck or filecheck.
the contents of keen1.exe:
mitted
epoll_ctl: Operation not permitted
(and the last line repeats itself on and on.)
Reply 14 of 19, by Rayek
wd wrote:
Do you know how to use the debugger? I think on the dev forum there's a short explanation somewhere. […]
I didn't see a difference in the 'meltdown' except a pause function. It basically says all it's going to say in the .txt file I attatched.
Plus, it's too much work to take screens 😊
Reply 15 of 19, by wd
Rank DOSBox Author
DOSBox Author
Well the interesting part would have been the screenshots
showing the progressing trace. But feel free to do heavylogs.
Reply 16 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
I allready figured it out.
the exe is corrupt.
it contains some sort of log message repeated over and over again.
Looks like a drive corruption.
Reply 17 of 19, by Rayek
Yeah, I think it's because they were rescued from an old Win. XP partition that had been blazed for one reason or another, saved to my Linux partition, and transferred back to the new NTFS part.
Thanks so much for the help, I guess I'll have to find my old floppies.
Reply 18 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
didn't know that there were reliable and stable
ntfs writing tools under linux.
I don't dare to use them to be honest.
Reply 19 of 19, by Srecko
There are few alternatives:
1.Captive (windows ntfs driver wrapper). Worked OK even a while ago, they did update it with fuse support recently.
2.ntfs-3g beta - reverse engineered implementation which is a small fork of linux-ntfs project (probably purpose of it was to create more attention and gwt testing as it was loudly declared as *almost* fully functional ntfa driver). It's a userspace fuse driver and will probably be merged back into ntfsprogs. Developers paid much attention during the development not to corrupt data and did not implement any FS operation which isn't well understood, thought they are almost done:)
3. Commercial Paragon ntfs driver which is rumoured to sometimes cause corruption 🙄
