The Soundcard is ALL
First post, by ynys
Tried dosbox before and was disappointed
After inserting soundblaster pci 128 (es1371)
Have had success with my favorites:
Lost Eden (cryo)
still before above mentioned soundcard
without dosbox (ie just run under windows) - no sound
with dosbox - no sound
now after soundcard transplant, sound in both instances but more stalbe with dosbox (under win some clip scenes ignored - probably too fast)
But particularly encouraging is PRIVATEER1 which needs acceptable DOS enviroment - have installed with sound yeeha, looking promising
BUT I do think, without sympathetic pci soundcard, little will be accomplished
As to what are sympathetic pci sound cards - early soundblaster? ESS? no doubt dosbox experts will know the good ones (and happily share?)
Regards
ynys
Reply 1 of 1, by avatar_58
Any modern soundcard works in dosbox, you don't need an early brand. In fact I think if you use too early a card you'll just get problems since it won't be compatible with XP (assuming thats what you use, else just stick with 98's native)
