First post, by 23.Prophet
hi all,
I use FreeBSD on my computer and i need Turbo Pascal for progamming on it. So i installed the DOSBox and then TP. It's all running well, but my layout.
I'm from Germany, so i need the qwertz layout, to handle with the DOSBox, it's really annoying to have another layout as i have on other computers i use.
So i installed the german keyboard-layout like it was descriped in the README File of the official german language support data.
But if I use "KEYB GR" (this command is already added to the autoexec) "he" announces "C:\GR.KL: Specified file could not be opened.". The strange thing is, that this file does exists in my mounted C:\ drive, and even in all other DOS-important directorys. I even can take a look @ this file via the "dir" - command.
So what should i do? I don't know where the mistake is, maybe i just forgot a simple, single thing (this would not be the first time 😢 ).
I hope you can help me,
best regards
da prophet!
