how to locate DMPI
First post, by greatrebel
I intalled dosbox 0.65 and want to run borlandc 3.1 compiler. When I typed the borlandc command, I got some error like: failed to locate DMPI. Does dosbox support DMPI. If so how can I locate it?
Thanks a lot
Reply 1 of 5, by eL_PuSHeR
Try playing with XMS, EMS, UMB memory options.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 5, by wd
Rank DOSBox Author
DOSBox Author
And be sure you installed your compiler correctly.
Reply 3 of 5, by greatrebel
thanks for reply. the compiler is just a simple exe file.
eL_PuSHeR, how can I set the xms, ems and umb memory options on dosbox?
thanks again
Reply 4 of 5, by MiniMax
Rank Moderator
Moderator
config -set dos "xms=true"
config -set dos "xms=false"
config -set dos "ems=....."
config -set dos "umb=....."
_________________
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
I'm quite sure that the borland c compiler is NOT just an executable,
but needs the rtm.exe and things like that.
