First post, by garcy
hey all,
i got command & conquer to woek all but the network play. i have enabled ipx emulation doesnt seem to help. i can get into the lobby but it doesnt see another person.
any help??
thanks,
Garcy
(long time no see Dosbox)
Games i got to work
Mechwarrior 2 (with some slow down)
Command & Conquer (almost perfect)
Dungeon Master 2 (almost perfect (no sound effects but music))
Reply 1 of 10, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
You know about 'ipxnet startserver' and 'ipxnet connect' ?
1+1=10
Reply 2 of 10, by garcy
no, could you talk about it thanks,
Garcy
Reply 4 of 10, by garcy
oh k thanks mate will look at that soon. i think i might need to open ports on my router if so, what ports?
Garcy
(i had a look at ports, i think the only one is 213).
Reply 5 of 10, by franpa
you do know that ipx netplay is for playing over a network and not the internet?
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 6 of 10, by garcy
yeh of corse i do, thats why i said network.
i have the ipx over lan enabled so i thik its a port issue but i need to know ports.
Garcy
Reply 7 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox emulates ipx. it doesn't use ipx to transport the data though(It uses udp).
and the portnumber is 213 and can be changed by specifying it on the ipxnet commandline
Water flows down the stream
Reply 8 of 10, by MiniMax
Rank Moderator
Moderator
The Internet is a network that uses the ICMP and IP protocols.
_________________
Reply 9 of 10, by garcy
what he said ^^^
and yes i am aware that the port is 213 UDP and can be changed, thanks for conferming this,
Garcy
Reply 10 of 10, by garcy
ok i have go it to work
played a game yesterday was great.
it was because of my static ip, i didnt have one up till now.
Thanks for your help
Garcy
